So I started wet sanding in a couple areas to see the results. With 1000 grit, I'm not seeing much change in the haze that I've been seeing. 1000 grit is what I used before and I'm thinking maybe I need to be more aggressive. I don't think pictures will show it well enough, but I'll tell you it is really easy to see the haze next to where the stripes were and that is kind of the area I've focused on. Is it going to be best for me to experiment with the next aggressive grit, like 800 and see if that is enough, then go from there? At what point do you switch to dry sanding and/ or a machine?
