Results 1 to 8 of 8
    Jul 2011
    fort worth , tx
    Default Timing specs for Mallory on 351W
    Just curious what y'all have you initial timing set at and also maybe a rpm break down too total advancement .
    I have been jacking with my timing to much and I just bought a new Mallory dizzy and wires from skidim and just need some "marine timing curve specs" please ....
    Aug 2012
    Wolcottville, IN
    86 Saltare
    Aug 2012
    Wolcottville, IN
    I think i just may have figured out part of my problems too... I have had my timing at 9 degrees, but i have a AV model on my 454 so it should be at 5 degrees...
    86 Saltare
    Jul 2011
    fort worth , tx
    Yes that does help .. Thank you . I believe 6 is where I need to be
    Jasun,
    I believe you just hooked me up with some of the info i was needing. Thx for the link. I have an 89 supra w the ford 351w in it.
    NJ
    Quote Originally Posted by jasun View Post
    For what it's worth I run 10* initial on my 454 with a Mallory Unilite. Forget what my total is and at what RPM.
    N.W. Suburbs Chicago, IL
    I also run 10 degrees before TDC.
    Aug 2012
    Wolcottville, IN
    Make sure you are looking at the Model number of your Mallory.... if it ends in AV then it should be 5 degrees and MV is 9 degrees (I believe... I saw a chart somewhere a couple weeks ago and now can't find the damn thing.....)
    Found it!
    http://www.correctcraftfan.com/Downl...Manual_New.pdf
    Check out page 14 for 454's and 9 for the 351's
    86 Saltare
