Results 1 to 7 of 7
    Aug 2013
    Exclamation Boat dies after 30 seconds
    Just took my '03 Launch SSV out of storage. It's been there for a year and a half. Put sea foam and 5 gallons of gas in it. Clean up the boat and took it to the lake. Engine starts just fine but will only run for 30secs and then chokes down and dies.
    I have to wait about 1 minute before it will crank again, but the boat still will only run for 30 secs and die. Any suggestions on how to fix this would be great.
    Dec 2012
    Clark, CO.
    sounds like a fuel issue. I would start with the fuel filter.
    Function before fashion!
    Aug 2013
    Quote Originally Posted by 2500HD View Post
    Anyone know what type of fuel filter I need?
    Mar 2010
    Windsor, Ontario
    Fuel issue for sure. I would get some gas line antifreeze, add it to the tank and fill with 92+ octane. Five gallons might not be enough to keep the boat running if the fuel level is very low to start out with. As for the fuel filter, record the number and bring it into cross reference at the local auto parts store.
    If there is still issues time to get a reading of fuel pressures on the high side of the pump.
    Tacoma, Wa
    shorter runs will solve you problem but that would get old quick.
    2003 Supra Launch 22SSV
    1986 Ski Natique 2001
    Jun 2013
    Syracuse NY
    Sounds like the fuel filter to me. Probably has a buildup and when it gets pressure it fills with crap and chokes out the engine. Change the filter and drain out the old gas. Unless you're running ethanol free the gas probably separated from sitting too long.
    1995 supra labrisa
    Pro boss gt40
    GPS Ridesteady
    May 2013
    Default Boat dies after 30 seconds
    Use some isoheat and change the fuel water separator/ fuel filter. And fill the tank half full that way if you have to drain it all its not 30+ gallons.
