I only skimmed the responses so i might be redundant.
I would start at 11mph and work your way up to 12.5, checking the speed with gps.
Is the bow playpen or walk thru? I run with my 1180 bow sac full. I'll often run a few hundred in the non surf side in addition to the 1100 surf side. Different boat but similar hull. The ronix Koal should work well.
Sent from my DROID RAZR using Tapatalk 2
