So tonight we ran the same weighting we did with the exception of moving the 150 from the rear center seat to on top of the tube sack in front of the 750. Basically moving one person to the observer seat instead of the doghouse. This balanced out us having someone in the rear seat for pictures and rope duty instead of having the bag and a person behind the doghouse, so pretty much the same type of setup we have run before.
I could definitely tell the difference in how long the pocket was and how much push the wave had. This was definitely due to the fact that the new platform sits different.
The new platform sits the same vertical height as the old platform, however it is technically higher because it is a solid, smooth bottom platform that is only on the brackets, whereas the OEM platform sits on the brackets and has a lip around it that extends about 2" from the top of the platform. So in essence, this design "raised" the platform 2" out of the water all across the board.
It also is about a foot shorter over all from side to side, so the sides do not dig into the wake and act as trim tabs. In fact, even though Trayson said the tip of the platform touched the water, in the video I am posting and in the pics you can see that none of the platform touches the water at all while at surf speed. It is truly an "unaffected ride" platform, no trademark infringement implied, it just literally doesn't affect the ride.
I have surfed this boat all summer and can easily say that this was the best wave it has ever put out. The pocket was longer and it had more push. Normally, being a bigger guy I had struggled to stay in the pocket and typically had to be really forward on the board. Tonight I had no problem staying in the pocket, my foot positioning was normal and I had to actually put on the brakes quite a bit to keep off the platform I had so much push I haven't experienced on this boat before. I had plenty of pocket to play around in and do some carving up and down the wake. I was able to do a few floaters to the back of the wave, drop down to the flats and just let the wave push me back to the front of the pocket. Something I have previously had a very difficult time doing.
The only other boat I have surfed is a 2012 Wakesetter VLX loaded up with at least twice the ballast as the Supra. While this wake did not have as much push as that, it was comparable. If I had to compare the two, I'd have to guestimate the Supra had about 75% as much push. I was able to ride the same way and play around on the Supra as I do on the wakesetter. This was a welcome surprise, considering normally I had to fight to stay in the pocket to even freeride the Supra.
With this good experience today, we are ruling it as a great success. We will definitely be moving forward with making the final version in the off season.
The only thing we noticed that might be negative is that with the "raised' platform, and it being flat, without a lip, there was more noticable exhaust coming from under the platform. Normally it would get caught in the lip and slowly escape when it built up or escape all at once when you turned the right way or stopped. A FAE build will definitely be in the future as well.
Enough talk, here are some pics, and some videos.
Rear/Side View:
Looks pretty stealth
Side View:
At speed, notice no contact with the water:
The edge and corner, also not contacting the water:
