Beautiful boat!
Cover- it came with the original Supra cover but it def needs to be replaced- where do I purchase a good cover (will only be used to travel with- boat stays inside a temp controlled bldg otherwise.
Skiboatcovers.com sells a very nice storage cover but I wouldn't use it to trailer. I wouldn't use any cover to trailer -- just asking for things to blow apart.
what are the best mods for the old 454 motor- she is a bear to start cold- any ignition changes or other insight??
I'd start with rebuilding/refreshing the carb. The kits are cheap and if you have half a brain you can do it. I was scared to do it for years and it only took me about 2 hours to take it apart and put it back together with fresh parts. Lots of help available on this forum if you decide to do it. I'd also make sure all your fluids/filters are clean, battery/starter cables are flexible and not-corroded, and I'd replace the points with a modern electronic distributor (your preference.) Do things slowly, 1 at a time so you can trouble-shoot any problems instead of changing everything out at once.
cleaning- inside and out- tips for the seats and carpet, and for the hull (it has some stains that I would like to get off so she looks good going in and coming out)
The sun will bleach your seats. I'm a fan of the dollar-store totally awesome cleaner for the seats. You can powerwash the carpet (leave it outside to dry out well in the sun after doing so.) Stains on the hull can be addressed with hull cleaner (muriatic acid.) That will remove just about anything below the water line. For stains above the water-line use some polishing compound on a rag or a Mr. Clean magic eraser. Be sure to wax afterwards.
and lastly- I have one small soft spot next to the little step plate on the port side (probably where last owner got in and out at the dock) but the rest of the floor and motor mounts are beautiful. should I pull the carpet up and fix or just wait til I need to redo the stringers (the will eventually fail)?
Knock on wood and hope your stringers stay solid. Depending on how soft it is, I'd probably address the floor during the off season. It is only going to get worse.
