I forgot to mention, I am using a mix of 1.5 oz csm, 1708, 3400, and 3610. Most it is scrap from previous projects. The resin will be using for this is a vinyl ester.
I drilled holes in the coosa board and resin coated it.
I created the "peanut butter" (resin, cut up csm, and cabosil) and used it to smooth out the transom before putting the 1.5 oz csm, then the coosa boards in place.
