Just a couple of tips -- soak the hell out of the bolts with PB blaster or penetrating oil for a couple of days before you start to remove them. Give them a liberal coating of anti-seize before you reinstall.
It also helps to get 4 bolts that are the same size but twice as long. You can put these into the front hole and the back hole to help "align" the manifolds before you put the other bolts in. They are heavy and it sucks trying to get them in the right position AND thread in the bolts, using the longer ones makes this a lot easier.
