I am switching out my gauges and switches. I plan on leaving off the upholstery helm cover and making a "carbon fiber" panels. I'm switching out the push button/breaker combo to rocker switches and breakers. I will be mounting the breaker switches on the inside of the stbd walkthrough storage. I messed up my first run because my spacing was too close. Originally it started with only the two panels, but now I'm making one for the center and lower steering area. I took rough measurements, drew it up in CAD, printed, and now I have to adjust the final CAD for cutting this week. The speedometer and steering wheel holes were purposefully made larger to be able to lay flat over the gauges and steering and used the concentricity to make the adjustments.
This is my old set up:
This is the new set up. The paper and wood pattern was just a mock up for adjustments and the panels obviously have not be mounted since they are wrong. The final set will hopefully be done early this week. I still have to get a new tach. I also got a new carbon fiber steering wheel. Hopefully I'll be able to run her this weekend!
