Quote Originally Posted by flipz96 View Post
Are you batteries run in parallel...or do you have an battery isolator or a soleniod? I would test it directly to battery to see if it stays on. If so..then its the breaker or something in the connection. If its the same, it might be the auxiliary battery thats bad.
I do have 2 batteries with the Supra switching system that allows me to turn on battery 1 or battery 2 or both.
I still have the same issue.
I did try to jumper the breaker and got nothing so this appears to be a power issue off the battery system itself.
