Thanks! It's been a labor of love - and hate. Here are some answers that will hopefully help some.
1. I used biaxial cloth - don't remember the weight. But I also used CSM. You'll need some of both.
2. People have done it both ways. I just epoxied the bottom and I'd do it the same way again.
3. I used PL Construction glue.
4. I don't have a foot pan. Those only came in the Comps (maybe the Conbrio)
5. Either 5200 or 4200 depending if you think they'll ever need to come out again.
6. I used an agricultural enamel paint. It's held up well. If my bilge were not accessible, I might have used bilge paint, but knowing I could touch it up if necessary, I went with enamel.
7. This one is up to you. I put carpet and wouldn't consider anything else. But either of those options will work as well.
I hope that helps. I don't remember how much material I ordered, but it wasn't enough. I needed slightly more cloth and a lot more resin. The cloth REALLY soaks up the resin, so if you are conservatively figuring up your resin needs - I'd double it.
