Can someone help me here. I'm done fighting with this Edlebrock 1410. I have the old Holley that was on the boat when I bought it but removed it cause of the leaking secondaries problem. I needed to get on the water quick so I bought the Eddy but its been trouble ever since. I think it is a 4150 600cfm but somebody ground off the numbers for some dumb reason so I'm not too sure which one it is. It has externally adjustable floats but looks like a marine carb since it has the down turned tubes. Also has a fuel inlet for a rubber hose and not the original compression fitting like on most 4160 marine carbs. Please don't flame me as I got it this way and I plan to put on a braided line with banjo fitting as soon as I get bugs worked out. I need to make sure I get the correct rebuild kit. Thanks in advance for your time!
