Results 1 to 3 of 3
    Default How to clean wake/ski tower
    I have a 2004 launch 22ssv with metal ski tower. Over time this tower has become oxidized and looking a little dull. Does anyone know a good method to cleaning these towers. I tried never dull and it didn't work to well just rubbing by hand.
    Thanks!
    Aug 2014
    Louisville tennesse
    Quote Originally Posted by onebadgt View Post
    Thanks!
    I've got the same boat but mine is an 03.my tower is has oxidized also i think the stainless is coated so I'm not sure what would would. I've tried wenol, mothers wadding compound etc with no real luck.
    Dec 2013
    If its stainless or un-anodized aluminum...use sand paper. The strokes must go in the same direction to match the factory brushed look. 100-120 grit is about right.
    If its anodized...I know of nothing that will fix it, other than re-anodizing, which is really prohibitive for several reasons.
    If its polished, then you still have to sand, but with much finer paper...like 600+ grit. It must then be buffed shiny using compound.
    To prevent oxidizing in the future, put a coat of wax on it every season.
