Hello all! I'm trying to replace my prop on me 03 SSV Launch. I loosened the bolt used the puller and it doesn't pop off like the ones on the YouTube video. I followed the instructions on tap the back of the puller then tighten several times until loose. However it is very tight and still has not loosened. It has moved about a 1/4" or so. The locking pin seems to have moved with the prop and I am unsure if that is the reason why it's not coming off. I am worried that If I continue to force it off unknown if the pin is the problem, I may make it worse. I've tried to push the prop back in also with no luck. I'm at a stand still until I can get some help on what to do next. What is supposed to be a 10 min job now seems to be a disaster. It's not dirty or corroded. Unknown when it was replaced or if it's been replaced in the past. Any advise would be greatly appreciated.
Corizòn
