 Junior Member
						Junior Member
		Just FYI, I just got the aluminum version in the mail, and it's MUCH stronger feeling. It's definitely worth the extra cost.
Did you not have a leash on your SUCKgate tethered to the boat?
-Mike
2006 Supra Sunsport 20V
 Junior Member
						Junior Member
		I did have it tethered. Somehow spun itself out of it. I'm also ordered the $18 aluminum one for version 2. Thinking about drilling holes in this one to alleviate some stress on suction from slipping. Might make like 4 versions and test them all out. Could easily build 4 for less than a Hundo
 Member
						Member
		This is the location I keep mine at. With all my ballasts full it's just out of the water by an inch, once I start moving it's under.
You can see the leash I use also, it's never come off. My blade dimensions are 8x12
I just ordered 1/2 hdpe. V2 will have the blade at the back instead of the front.
 Junior Member
						Junior Member
		Ice... I bet I know what happened with yours...
From other pictures, your leash on the bungee looked to go through only the arch on the shelf bracket. I'll bet when the SUCKgate came loose, it just ripped the weld of the arch off and came undone that way because of all the water pressure/resistance when that bungee hit its max extension. I put my leash around the handle and the lower shelf supports that were bolted to the HOD. You can kind of see that in my picture sitting on the back of my boat.
This is all assuming you didn't lose the bungee tie. If your bungee cord came off the boat entirely, then I'm totally off base here haha.
-Mike
 Junior Member
						Junior Member
						 Junior Member
						Junior Member
		V2.
 Member
						Member
		Bunch cord that I found at Home Depot!
https://www.homedepot.ca/en/home/p.b...000804722.html
Blade is 30 degrees, my blade is in the front of the Suckgate, next version will be at the back to see if I notice any difference.
 Junior Member
						Junior Member
		V3 finished! All new design, aluminum alloy body, stainless construction, and better suction.
