Quote Originally Posted by River-rider View Post
Drained it from the plug in the bottom both times if the intake line was cracked and water was getting in would the level not be high and if it came in would it not also drain oil and water out when the boat is out of the water leaving the level in there low ?
What you say is likely true...but depending on the crack location it could just be swapping water and oil back and forth.
