I agree about having him do any more work. Said he worked for a Supra dealership in GA so I trusted him. He said the timing light wouldn't work on cylinder 1 so he used 3. Again everything I read says to use 1. He left it in worse shape than what I had it in. He said that because my carb is bad and the distributor clips aren't tight he couldn't tune it. That maybe the case but at least I had it running before he touched it. OneAnyways, I think I am going to upgrade to an electronic distributor. Does anyone have any recommendations on the brand and model. I have looked at Mallorys in the past. Is this something I could order on Summit or Jegs? Any help would be appreciated. I believe the engine is a left hand rotation does that sound right. Also, when I started to check the spark plug wires the other night prior the guy coming over, they didn't seem to match any of the diagrams I pulled up for this engine. Does anyone have the right wiring diagram for the plug wires for an 84 PCM 351w?
