Originally Posted by
Broke Pilot
Mine is for sale... It sucked, not in a good way. It doesn't work well on a 24ssv. First problem is it slides all around unless the boat is dry when you put it on, no real solution to that. I tied a rope to it off the front cleat, it kept it from sliding back and from there I moved it all over the side of the boat. High, low, front back, and played with ballast and wake plate at each platoon before I moved it again. I'm tired.. Getting in and out of the boat, surfing, moving the gate.. It was exhausting research for no payoff lol.
The best wave I got was as far back and low as I could put it. The wave was pretty, but it had zero push unless I drained the middle 1200lb bag, but then the pocket got so short and close to the boat it wasn't worth having the gate on.
Only thing I might try is a shallower angle on the plate, but I don't see that helping.
I'm working on pics... Can't seem to get them to upload for some reason tonight.
i think the shallower angle might work better. i see people using a steep angle and getting mixed results. I'm having good results with about 35 degree of angle off the boat hull, but im also in an old direct drive sunsport.
1988 Supra Sun Sport 454 PCM
1972 Olds Cutlass 455
1998 BMW 750il
1996 BMW M3 coupe
1995 Toyota Tacoma 4x4
