Results 1 to 8 of 8
Threaded View
  1. #6
    Sep 2009
    Geneva IL
    Definitely more weight will affect your wake if you do indeed have stringer rot. But your boat wake or mine (96 ts6m comp) will never compare with a 99 nautique tsc hull. Or a malibu sv23 diamond hull. Especially at slow speeds learning the course. Not sure on the MC never skied that year. In the mid 90`s when boats were changing to pure slalom tugs supra kept there hull as a true 3 event hull which needed a nice trick wake. Hence that nasty bump at 22 off. I remember the article in waterski mag. If I remember right it said good shortline wake at 32 off and shorter. I dont think the 15 off is too bad. But the 22 and 28 off length is tough. With mine I put a 4 blade oj prop lowered the wake plate 1/4 inch and put a 150 lb fat sack under hull and its a little better. If your looking for a bigger open bow boat with a great wake. Check out a 96 and up malibu sunsetter with sv23 hull. You will be amazed at the slalom wake for a bigger boat.
