The new MC rudder port I used was also bigger on the OD of the tube. I was originally planning to bolt plywood to the hull, mark center, and drill appropriate size with a hole saw. Turns out it was not really much bigger. I used a small 3 stone cylinder hone on a drill with 40 or 80 grit sandpaper wrapped around it. Didn't take too long to open up the hole and I was able to sneak up on it for a snug fit.
Sweet , I have a ball stone I was thinking of using , I contacted machine shop today and said he could have it done in a hour . Still checking push rod length on the engine and then I should be ready to install this thing .
