Ok I got the heads dialed in all within
.020 of 1.900 installed height on the springs , no coil bind and seal to retainer is .200 so I bolted the heads up and installed the roller lifters and spider hold down bracket with dog bones , rockers should be here Monday to check for push rod length and then order push rods , I also decided to buy a new rudder assy because mine is worn past and is leaking , so more to come on that and I listed in another thread if you would like to follow ,
Here are some pics of what is going to look like and progress !
