Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
  1. #11
    May 2008
    Mt Juliet, TN
    Quote Originally Posted by PBWolf View Post
    Not the impeller itself, but the entire pump can be put on upside down so that the inflow hose is now hooked up to the outflow. Only an issue if you actually took off the entire pump, not just opened it up to take out the impeller.
    His engine has a different style impeller pump.
    1987 Supra Saltare
    PCM 454
  2. #12
    Aug 2014
    Huntsville, AL
    Quote Originally Posted by leetudor View Post
    Oops! Disregard my statement then..
    1996 Supra La Brisa
  3. #13
    London, Ontario, Canada
    do you have a water strainer?
    2009 21v Worlds 340 Cat
    Doug
  4. #14
    Not sure to be honest
  5. #15
    Check all your intake hose clamps, you could be sucking air. Remove your thermostat housing and check for corrosion or other deposits and assess your tstat to start
    Doug
  6. #16
    Dec 2013
    Quote Originally Posted by torch View Post
    That's pretty critical to know if you are winterizing your own boat. Unless it was removed, you should have a strainer...and if you have never checked/drained/ or cleaned it, that very well may be the problem. If it froze over the winter, it could have cracked. Then, being on the suction side of the pump, the pump may only be pulling air. And, of course, you may have lucked out and it is just clogged.
  7. #17
    Only strainer I am aware of is for ballast and the scoop strainer under the boat. But I'm no expert and may be missing something
