2008 Launch 24SSV Hard to start 5.7 Indmar 340hp
I have only owned the boat for 2 months now, had to repair quite a few small things before I could take it out on the water. So the problem is it's very hard to start cold or hot. Once it does start it will run perfect all day, if I shut if to take a break for awhile same thing turns over fine just doesn't want to start. I was just curious if anybody had run into this issue before and could lend a little help. Thanks in advace.
