When you stop the engine the coolant flow also stops . The engine will heat up because of no coolant . This is called a hot soak . Its normal . You can shoot the thermostat housing with a Infrared Thermometer gun to check the real temp. It sounds more like you need a carb overhaul. Float level too high, float needle not holding or power valve leaking.
