					agreed that the upholstery is odd, but that can all probably be redone for around $2k or less if you shop around and if you care that much.  if there's proof of a stringer rebuild (paperwork), that first boat is worth the money for sure with a rebuilt trans and engine.  for the peace of mind though, $7500 for a non-wood boat might be worth it--i think 93+ had fuel injection as well?  literally all you need to surf that sunsport hull is 2000lbs of ballast and a suckgate of some sort, so that's not a hard add.  let me know if you need a hookup on bags and pumps once you get to that point.
