Quote Originally Posted by Tonymozingo View Post
89 Supra has been on rack for ten years. Almost full of gasoline.
I’m installing a new carb.
Question: Is there a reasonably easy way to drain the old gas from the tank, and if not, what should I do as far as an additive, etc. ?
Definitely get the old gas out.
As simple as a syphon tube!
Try to agitate the fuel remaining so as to get out the crud as well.
Then add about 1/8 tank fresh fuel with additive , agitate best you can and syphon that off
Change fuel filter.
