Originally Posted by
tg0824SSVGG
First thing that comes to mind about the speakers, other than obvious stuff
like making sure there are no blown fuses (doubt the lights would be on tho).
Make sure all the connections on the RCA lines from the head unit are tight on both ends.
Find the "Fader" setting on the head unit. At least on mine, the "front" outputs
are hooked to one amp, the "rear" to the other. If it's set to be all sound to the "front"
or "rear" instead of a mixture, then it would explain only getting sound from one.
Speedo - yikes, if the electronic display is showing the speed, but not the
actual speedo - sounds like something wrong in your cluster - since the pickup
(paddle wheel) must be working. How far away is the dealer?
