Turn off auto wake. I would only use if you have 6 or more people in boat and just having a fun run. We run 150 each rear corner and 100 under each tower. 100 percent to surf side, 95 to other. 60 to 70 front, less if you have people up front. Easy peezy, at those settings and only driver in boat the wake is fantastic, clean, useable and a ton of push. 10.6 to 11.4 speed based on preference etc. You can slam way more weight into this boat but the tsunami that ensues is past ridiculous and most pros will make us reduce it. Don’t confuse a huge wake with a good wake. My two cents.
