It’s tricky until you know how to do it.
There is a “top” tag on the cover, that obviously goes over the top and fit around the tower light/tow point. There is a U shaped cut out that aligns with the tow point.
Once you have the top aligned, the cover wraps around the front edge of the folded Bimini, the tucks under the tower roll bars.
Once tucked under the tower bars, the rear zippers should align.
Zip rear zipppers.
Then on both both outboard port and starboard sides. There are two short zippers to attach.
Let me know if you need pics?
