Both good suggestions to look into.
I replaced the condenser today...did not seem to do the trick. I'll get new points and dial those in and make sure there are no vacuum issues. The carb does have vaccum secondaries so I'll look into eliminating that as the culprit as well.
We did manually open the secondaries and feed it fuel while on the water..the engine should have been screaming at that point but there was no change. Any thoughts on that.
What it feels like is happening you get the throttle about halfway and things are going okay but after that as you press the throttle nothing changes. No increase in power or change in RPMs as if the throttle cable is not engaging with the throttle on the motor/carb assembly.
Thanks again for the suggestions.
Reason: Additional info
