Hey guys and gals,
I pulled my transmission over the winter to rebuild it, and it got put off way to long due to priorities (other hobbies . I ended up replacing the rear main seal, flywheel ring gear, damper plate, and freshened up the tranny. I got it all back together, and bolted up finally. I felt really great about the install, and getting everything lined up just right... within .002
I hooked it up to the hose for a test trial before dumping it in the river, and couldn't get the thing to start.
Below is a picture of a couple of plugs that I can't figure out what they are. I don't believe they were hooked up to anything, but please tell me if I'm missing something?
Also, looks like the 60amp breaker is popped, but it will NOT push back in. Put a multimeter on it, and one side was 13v solid, the other was bouncing all over the place. I put tried the meter on the other breakers as well, and found the same thing??? 12v solid on top post, and bouncing all over on bottom post?
I'm confused and don't know where to start. Thanks!!!
