Quote Originally Posted by dpike View Post
Ok. Thank you. I forgot to say that right before it started bogging down this last time, it started having a heavy vibration on accelerating but would stop after easing back on the throttle. It had a similar vibration when I bought it, replaced the prop and it went away. Any ideas?
Hmmm. Why did you replace the prop before? Did you hit something? What does the prop look like? Any damage? Did you check the prop shaft to see if it was bent? You could possibly have a misalignment problem, but it wouldn't have gotten better with a new prop. I think there's something going on with the engine causing the bogging/vibration.
