If your looking for the drain for the oil it’s in the port side with and oil line going through it. When you pull it off you’ll see an oil screen as well. I had water in mine. Had to clean all that out and then it took a few oil changes until I got all the water out.
Thanks I will check it out tonight. So to make sure I understand, there is actually an oil line going through the drain?
Also I assume this means the insert in my photo is not the drain?
