Quote Originally Posted by secondsupra2004 View Post
Can you have someone ride with you the next time you take it out? They can drive and you can look at the carb whiles its under load and see if the secondaries are opening and if it is getting fuel. When was the last time the carb was rebuilt?
Yes I’ll have to do that on Friday.
I ohm tested the coil, not sure if these readings are ok or not.
Room temp: 1.6 ohm across +/-, 10750 ohm across neg and center post.
Warmed to 150 degrees F: 1.8 ohm across +/-, 12190 ohm across neg and center.
These seem to be a lot higher on the secondary than other members have posted on claimed good coils
