Well, Jim’s Prop Shop doesn’t repair rudders anymore because he said they often break before they get completely straight. Metal shops in my area won’t repair it because it’s either a small job that they don’t want or they don’t have the ability to braze weld if needed. I guess I’m either going to need to source a used one or pony up the money for the whole new rudder and rudder box or run it as is. I bent it just prior to putting it in the trailer so I don’t know how it will work but I guess I’ll put it back together and give it a try. I can’t tell for sure but it might be cracked/torn at the base of the shaft so I don’t feel like it’s very safe to use it long term.
