I also have the LED going to the accessory side on the switch
So you are using the remote indicator (LED) terminal off the ACR? That output terminal is wired to the negative side of an LED and the LED is wired to switch? Or sis you run a wire from the LED terminal direct to the switch with no LED in the middle with correct polarity?
Your ground BUS is fine, as long as the ground cables between the BUS and batteries is of proper gauge.
Also looks like there are only 3 cables exiting the switch. I presume main starter cable, cranking battery and house battery. Are there no house loads?
Michael
Mikes Liquid Audio
