December is now over and most of the hard work with the stringers is a thing of the past. Moving into January and the new year, it was time for new foam to be put down before the flooring pieces were cut with precise care. It was a thing of beauty to see it at this stage and comforting to see how much they cared about their work that no one will ever see once the carpet goes down.
Originally, the boat had half inch plywood for the flooring and when I had the last stringer repair done, I was told it would be 1/2" as well. When you pay someone for 1/2" marine plywood, you just expect that's what they would use. I did have one low spot in my floor and wondered why it flexed as much as it did. It also wasn't level at the bow area. I began to question a lot of things shortly after the repair done in 2009 but still trusted in what I was being told and she ran real good so did not focus on those small things. Imagine my surprise almost 12 years later to the date when the new shop tells you that the floor was 3/8" and looked like basic plywood. If the stringers did not rot first, only be a matter of time before the floor did. A WTF moment for sure. I think at this point, I wasn't really surprised. Even after learning of the first betrayal years earlier regarding the stringers, you go back and replay all the conversations in your mind that you had with a crook and it all starts to make sense now as you see the entire fraud presented before you.
If you're keeping score at home, so far the Crook = 2, Boat Owner = 0
That is 2 outer stringers not replaced that were supposed to have been (that I paid for)
3/8" basic plywood for flooring instead of the 1/2" marine grade (that I paid for)
