Thank you MySupra!
1. Can you get me a shot of the wiring under the 'PCM PowerPlus' Fuse cover? There are a couple of wires running in under the cover I am trying to sort of the location of.
2. Is it a 5" or 9" transmission oil cooler? I found them here: https://www.myinboardmarine.com/sear...&type=product# but am unsure of the size. My original measures over 5" and under 9".
3. Where to the water hoses run to/from the top and bottom of the transmission oil cooler?
4. It looks like you have a green handle valve. What is that for?
