Hello all.
87 Sunsport. Noticed a bit more than usual (water) coming in from shaft seal this am. My question is this. The water here is currently just above freezing as it is snow run off.- Would this affect the amount of water penetrating- or is it time to adjust the lock nut/coupler- or repack the seal?
From what i've read- it is easy to over-tighten the system... How would i properly repack seals, and with what? And/Or how is an adjustment made without compromising parts/ seals?
Thank you in advance for any help.
dp
