How do all you guys clean the carpet in your rides? I vacuum mine with a shop vac frequently and use normal household carpet spot solver when needed for little stains.
Taking the boat out for a good cleaning tomorrow and wanted some tips.
Thanks!
Thanks!
If you have access to a carpet cleaner with an upholstry cleaning attachment that works very good. You can rent them at your local hardware store for about $25, well worth it. It will do a great job on your carpets in your boat.
I use a Little Green Clean Machine on my carpet. It works pretty well. It would be the same thing as using a carpet cleaner. It wouldn't say it would be worth going and buying just for cleaning your boat, they are about $100. We have puppies and white carpet in our house though so we get a lot of use out of ours. If you could borrow one from somebody you know, that might work. Good Luck!
2005 Supra Launch 22 SSV
Semper Fidelis
Thanks for the tips guys!
I clean my carpet the same way I clean the carpet in my house. The trusty old hoover carpet cleaner. Basically a shop vac that shoots a water based carpet cleaner then vacs it right up. Gets ride of all those stains from lake water and spilled drinks or whatever.
