CM --- start here, there are others, but if you want to see what John did, step by
step - it's probably the best:
http://supraboats.com/bbs/showthread.php?t=3792
oh yea, and John ... now that I look at that series of photos, I am reminded of your
lighting under the swim platform -- how did that turn out once you were in the water?
Not worth a crap Bub.... I plan to redo it soon. The problem was the hyped-up swim platform bracket connections. Not such a good connection. The lights just barely glow in our dirty water. Still pretty cool when they'd work.
As for the amp install, that's basically what I did. The Masonite is covered in black carpet, amps are screwed to it. I only did that to make the surface flat. The top left of the piece doesn't have anything screwed to it because that's where it curves, and that masonite isn't strong enough to support the weight of anything. The 2 Syn1's are on the panel, the Syn6 is mounted flat to the hump, and the Syn4 is on the right side. It's just a simple install that puts the amps out of the way so they don't get hit with anything. All the wires have loops and are screwed down so everything in there is very tight.
I had thought about changing it up a little, mounting the amps on the gunwhales and doing something a little more custom with LED's, but it wont be this year. I've already got too many other installs lined up and my boat heads to the dealer for lots of work here in a few weeks. I did sell my Pro485 and will either add another pair of Pro80's or a pair of MB-8's. I'm leaning towards the MB-8's....
Taylor if you have any questions, feel free to ask.
07 Launch 24SSV Gravity Games
My Install Gallery
Thanks guys. I will start here.
2004 Supra Launch SS
