Just plug n played a 1100 for my 450 and it fits no prob with room to spare, will post pics and video link later
2009 21v Worlds340 Cat
Doug
here are some pics , the 1100 is close to capacity in this shot. the other compares the stock 450 to the 1100. It took about 10 minutes of fill time on the jabsco pump. The bag emptied a bit out thru the overflow...will have to put a shut off ball valve on this line
Doug
do you have the play pen or the walk thru?
Doug
Doc, Thats going to be one sweet surf wave!
White/Charcoal, 2011 VLX
2008 Supra 22SSV
thats what i'm hoping for fman. I only bought one for my surf side and am feeling guilty about the other......i suppose i should at least get a 750 for my daughter....or do i have to be an equal opportunity captain?
Doug
Thanks for update Doc.
I wonder how the compartment size compares with your 09 to my 05? I'd love to upgrade to your setup.
It would prob take 30min to fill with the sprinkler system...but worth it.
here is a video on filling it, the video was 11 minutes long , i cut it down ,about 2 mins and i had to reset the pump every 30 seconds after 4.5 minutes as i need to reset my timer so it prob takes about 10 mins. As you can see i can add more weight as i am not close to my rub rail
http://www.youtube.com/watch?v=q1zLBOeMr_g
I'll measure my compartment when it stops raining
Doug
if i had the sprinkler system i'd 1. swap out the sprinkler valves for new high flow valves 2. Y the opposite side sac valve add ball valves and have the extra line run over to your surf sac vent hole so there would be two lines filling it. then you would be down to prob 10 mins of fill time or less for a 1100lbs
Doug
