Results 1 to 10 of 123
Threaded View
  1. #11
    Mar 2009
    Roseville, CA
    Quote Originally Posted by ScottnAz View Post
    The hose is very similar to the OEM ballast hose in my boat. It was flexible and easy to route, and I don't think I'll have a problem with kinking. The hardest part was getting the fittings pushed in to the hoses', tore my hands up.
    The system is all complete, and has been through a few lake tests. Everything seems to be working great. The only thing I'd like to change is the drain pump locations. I installed them so they have direct connect with the bags, instead of in the engine compartment, for more consistent and reliable draining of the bags. To preserve room in the rear lockers, I installed them on the front of the bag, up against the rear seat. Now the bags don't completely empty, whereas, I used to be able to get the last bit of water out of the bags while driving. It's not that big of deal, I just unhook the rear bag vent and roll the bag up like a towel to get the remaining water out and allow the compartment floor to dry from the days events. I'll try it this way for the summer, and re-assess the situation during the break in the season from Dec-Jan.
    Hey Scott, great job. I did the same with the drain pumps, except I have mine off the back of them and it works great, I can get about 95% of the water out of the bags. Getting them out of the heated engine compartment is a great idea, and if one takes a dump they are very easy to replace this way.
    Heres a couple pics of the rear drains and the flexible upgraded line I really like.
    White/Charcoal, 2011 VLX
    2008 Supra 22SSV
