Originally Posted by
sybrmike
Finally found a set of metric bolts (the only metric I've found on the boat) to thread into the steering hub & a puller took it right off. So the dash is finally out.
Now I'm planning the new dash layout (still looking for modern rocker switch source). The old dash had idiot lights for oil, temp, fuel, & amps. Speedos & a couple other gauges were not working when I bought it & don't know if the warning module works. Is there a way to test it? Aren't these things tempermental & prone to false buzzing? Should I even bother with it or just trust myself (and others) to watch the vitals?
Thanks
You're a braver guy than I -- I had planned on rebuilding my dash. After a bit of fishing around with a multimeter I decided that unless I end of marrying an MIT Electrical Engineer -- that dash is staying exactly where it is. Holy balls did they make that thing needlessly complicated!!
