I too found dry rot in my 89 Comp on the spotters side. I removed a section of the floor and discovered the support beam partially rotted. The dry rot in the floor goes partially under the seat. I need to remove the front seat. However, there is fiber glass portion on the bottom of the seat that appears to be molded to the rest of the boat. I was wondering how do you remove the spotters seat?
