I have a 09 21v . i am getting water in my bilge and for the life of me cant figure out where its coming from. I've checked all the hoses to and around the motor for drips,leaks and nothing......maybe i'll try shutting off my ballast valves and see if i still get water......any ideas?
Could it possibly be a bag connection leaking once filled? I have noticed I accumulate some water in the front ski locker area near my front 400 lb bag. I tested the bag for a leak and could not find anything, my next step will be to see if the hose/Tsunami pump is leaking a little once the bag is filled.
Sounds like a good idea to turn off your ball valve to the ballast fill system and see if you stop getting water. I would doubt your shaft seal is leaking with an '09 but anything is possible.
Knock on wood, but my rear transom area bilge is always bone dry, I have never even had to use the rear bilge pump.
