Results 1 to 10 of 12
Thread: 1100 lb Bag
    London, Ontario, Canada
    Default 1100 lb Bag
    Just a note to all who use this and maybe the 750lb .......i've noticed some bowing of my engine compartment starboard material between the 2 hinges after multiple uses of this bad bag.......I would suggest a 3rd hinge or a metal angle bracket behind the hatch to prevent the bowing......also the screws attaching the hinge to the door are pretty short.....would suggest longer screws or thru bolting with washers to prevent failure due to the increased pressure from this big bad bag
    2009 21v Worlds 340 Cat
    Doug
    Mar 2010
    Western ok
    I'm going to double check mime this weekend thanks doc...
    Jul 2009
    Maryville, TN
    Doc, mine did the same thing and I did exactly as you mentioned. I used longer screws that is, not the additional hinge.
    2005 Supra Launch 24SSV
    Mar 2010
    South Carolina
    Default Pics of this monster?
    Any of you have pictures of these 1100 lb. bags filled in your lockers? I really would like to see this. Or perhaps take some this weekend and post them up. Those bags are 8 inches longer and 8 inches wider and taller than the 400 lb. bags I have stock (W713) and I am eager to see these things in someone's lockers.
    Mar 2010
    Dale Hollow Lake Tennessee
    I strongly suggest the extra hinges. I haven't installed mine yet, but Scottie (ssmith) has installed some and they have made a HUGE difference. I hope to install mine this weekend.
    So far, I have just been watching my 1100 lb bag closely when filling and just haven't been filling it completely since I know this is a problem.
    2007 Moomba Mobius LSV with 4 Exile XM-7s, 2-s400, 1-xi800, 1-xi1500 amps. Cabin speakers- 6 Exile XT65s, Sub - Exile Big12. 2 Stinger batteries, and a few other goodies
    Feb 2010
    Calgary, the rockies
    on my 22ssv everything seems fine so far, I should take a look to be sure.
    note to self when removing bags to dry locker after putting bags back in HOOK them up. I was sitting on the lake for at least 5minutes or more and it seems my bilge is going but platform is not going down as my bag fills hmmm I pop open locker to see the water flowing for over 5 minutes,, doh....
    thats 5 surf minutes i will never get back.....\\
    Feb 2010
    Quote Originally Posted by cigars n scotch View Post
    I will get u pictures tomorrow, the lid on the locker will just pop open if you let them, I turn mine off when it starts hitting the fiberglass edge. maybe a vest would fit in there otherwise full. then i leave 2 or 3 hundred pounds on the non surf side
    http://supraboats.com/bbs/showthread.php?t=6139
    here is my thread on this bag , scroll for pics and video i inserted on it
    Doug
    Mar 2010
    South Carolina
    thanks for the vid and the pics. Question for you: in your 2009 did they upgrade the pumps from the sprinkler valve? You're filling your bags at a standstill, I could have swore my dealer told me that the boat has to be moving in order to get suction into the gate to fill the sacs. Just curious, perhaps newbie question..
    2008 Supra Launch 21V - Currently for sale
    Feb 2010
    good question on the 09's,,,, my 06 needs to be primed I usually get going 10-15mp/h for half minute then I can just sit and fill, if I turn the boat off i think the pump slows quit a bit, only tried that twice and seemed like forever to fill.
