Has anyone tried this? It is an app that controls the volume based on your speed. At $.99 it comes in a little cheaper than the HSE.
I plan on trying it this weekend and will note my results. Just wondering if anyone else is using it?
Despite the fact I have the HSE, my curiosity was peaked when I read about this app on WW. From reading the description of the app, it seems you need to have cell service in order for it to work?
So, my question, is that clause strictly for the 2G? I've got the 3GS iPhone, but, terrible to non-existent cell coverage on the lake. Does the 2G not have GPS capabilities, and therefore needs to ping a cell tower?Although Adaptunes works on iPhone 2G, be warned that you need a very strong cell tower signal in order to have location accuracy high enough for Adaptunes to work properly. Without a stron signal, speed-based volume control is unavailable.
Adaptunes just needs a good cell signal on the original iPhone because it doesn't have a GPS chip, as you assumed. The iPhone 3G, 3GS, and 4 all work without a cell signal just fine.
I'm actually the developer of this app, if you have any other questions I'd be happy to answer them.
Does this application exist under andriod based phones?
I am finally getting rid of ATT and the iPhone Thursday!!!!!!!! Thank god.
AlphaAcid,
a few questions:
* I am assuming this only works out the headphone jack, or are you somehow modulating the signal out the bottom (which is how I have mine hooked into the boat)?
* It's not obvious how you adjust the set points (at least to me) -- could you clarify, or call me a dumba$$ and tell me where it's documented?
* do you have plans to allow other "players" to be used, like Pandora, or just the stored-on-the-device files?
Thanks,
Todd
Also it has been documented that in using the headphone jack causes the eq to distort and can damage speakers. We ONLY use the dataport.
does this work with an ipad touch? On the website it says it does but I don't see how it would without a GPS thingy.
Make sure the settings on your player are set to flat.i just got New phone and it was set tobass boost out of the box and sounded like crap when I plugged it into a stereo.
As cheap as the rca cord is make sure you get a quality one.check out monoprice.com for cheap cables of any kind!
I use the new Iphone4 and I dont see anywhere that it has a bass boost. But I probably need a better adapter.
