Quote Originally Posted by agetech View Post
That part is the resistor for the ignition. Looks like part of the porcelain shell just broke off. Don't worry about it, if the boat starts, it is good. The boat will not start if that resistor is burnt out. Don't tape it, it gets hot when engine is running. The resistor is not needed if you convert to electronic ignition.
What does the electronic ignition in tale? Does it have anything to do with points on distributor? Or is it just changing the ignition on the dash? I was talking to my mechanic and he was saying that i should check if there are points on the distributor and if it has them i can bypass the resister all together. Or maybe he said if it doesn't have points...
I got the part, the boat shop called it a ballast resister, pcm 351 manual called it ignition resister like u did, installed it and all works well... My RPM gauge even worked for a min, but then it locked in a position between 1k and 7k again... so i'm at a loss with that one, but i'll work over the winter to figure it out.
