2000 LAUNCH, need to change tranny fluid & never done it. Also how do I clean/replace the tranny filter and/or the tranny housing where fluid runs around the intake water for cooling? How mant qts? TIA
http://www.moomba.com/msgboard/showthread.php?t=10977
look in your manual or print one of from the downloads on this site. no need to clean your tranny cooler
2009 21v Worlds 340 Cat
Doug
Tranny is a ZF Hurth Model HSW 450 D- Is filter screen inside the return line connection? Not the same configuration as MOOMBA site directions. TIA
ok this is the same tranny , the screen is in the tranny on the bottom. feel for the rectangular coverplate with 2 bolts on the bottom of the tranny, if you have your manual it will show you in the diagram where that screen is located. The ? is whether you have evough room unred the tranny to remove it. you need about 1.5 inches of free space
Doug
